KfirTito
3 years agoDevice configuration failed + CRC error while using .jic file
Hi, FPGA model : C10LP120YF780I7G, Vcore = 1.2V , Vccio = 3.3V (conf dev IO voltage) Flash model : MT25QL128ABB Conf Scheme : AS (x1) , MSEL[3:0] = 1101 (AS, Fast, 3.3V) JTAG Conf : Single Devic...
WZ2
3 years agoHi there,
I have already check your sof and the process of generating jic, there is no problem. There are some points I want to make sure again:
1. Is the logic code work when turn off the “AS MODE Conf_done error check” and power up after load the jic?
2. Could u try to read the rpd(bin) file from flash and compare the file with your rpd file when you generate the jic file?
3. On your board, is the config_done pin is floating?
WZ
