mthimm2
4 years agoDetermining Internal Oscillator Frequency on Cyclone V
I'm using the internal oscillator of the Cyclone V as a clock source in a circuit that I'm implementing.
The circuit revolves around the propagation of signals through a series of adders, meant to...
SyafieqS
4 years agoHi Maxwell,
From the attachment. regarding the warning issue, Node: challengeModule:cm|outTerm[0] was determined to be a clock but was found without an associated clock assignment,
This can be caused in two ways:
1) A clock assignment was determined to be invalid, so its source objects no longer have a clock associated with them.
2) When analyzing the netlist, the node was found feeding a clock port with no other clocks feeding it.
Use the derive_clocks command to automatically find all clock nodes in the design. Also, for any clocks that were ignored, review the warning or error message associated with the command to prevent the clock from being ignored. Specify a clock assignement using create_clock or create_generated_clock tcl command.
