mthimm2
4 years agoDetermining Internal Oscillator Frequency on Cyclone V
I'm using the internal oscillator of the Cyclone V as a clock source in a circuit that I'm implementing.
The circuit revolves around the propagation of signals through a series of adders, meant to...
SyafieqS
4 years agoHi Max,
What Quartus are you using?
If you are using current version, there is a feature called design assistant rule check that help you with timing and warning.
You can enable what rule intended.
