14 years agodetecting rising and falling edge
Hello. I have an Enitiy that have in siraial input ,clk and output bus. i need to count time between falling edge of my input until rising edge of the same input but all this needs to be s...
14 years agoHere's what you need to do;
1) Route your serial clock through a dual-DFF synchronizer that is clocked by your main clock. Lets say the input is called sclk, and the output is called sclk_sync. 2) Route sclk_sync through another DFF, and call that sclk_dly. 3) Draw yourself a timing diagram of sclk_sync and sclk_dly. What logic operation do you need to detect the rising edge and falling edge? Hint, what does 'sclk_sync and sclk_dly' look like, how about 'sclk_sync and not sclk_dly'? One combination will give you the rising-edge, while another will give you the falling-edge. 4) Create logic to enable/disable a counter clocked by clk, where the enable/disable logic is based on the rising-edge/falling-edge logic. Try to figure the logic out. If you get stuck, ask for help. Cheers, Dave
