14 years agoDetect presence of USB Blaster local to target?
Hi, I would like to have my target detect when a JTAG header is connected so I can disable the default JTAG controller outputs (using an output enable). The header will only be used during produc...
14 years agoAs an additional remark, you can bypass the sense pin with e.g. a 100 nF ceramic capcitor directly at the connector, so it's still working as a ground, AC-wise.
