14 years agoDetect presence of USB Blaster local to target?
Hi, I would like to have my target detect when a JTAG header is connected so I can disable the default JTAG controller outputs (using an output enable). The header will only be used during produc...
14 years agoUSB Blaster output pins are initially tristated so connection of the USB Blaster isn't detectable by a level change. The only simple method I can think of is to use one of the two ground pins as sense.
