16 years agoDesign not Fitting in LogicLock Regions
Hi. I am having a trouble with LogicLock Regions. I compile the Design first with the LogicLock Regions, set to Auto and Floating. Then once it fits correctly. I change it to Fixed.. and star...
16 years agois your region's location the same as when Quartus placed it? a column of DSP blocks will leave you with fewer LEs, for example
if everything checks out i would open a service request and file a bug report. in the mean time can you increase the size of the region slightly to get it to fit?
