19 years agoDesign no longer compiles. IEEE-1532 error
Don't know what I did, but my design no longer compiles if I use MAX7000S family. Error message says: "Device or configuration device EPM7064DT44 not IEEE-1532 compliant." Some other fami...
19 years ago --- Quote Start --- How to make it automatically assign pins? Then go back and change them so the layout is easy? --- Quote End --- If the target device you select is"Specific device selected in'Avaliable devices' list then you shoule assign pins else no need; end if; A Quartus_hand book may help, try it. Good luck.
