15 years agoDesign constraints for DDR SDRAM interfacing with cyclone3 FPGA
Hi all, I need to interface DDR SDRAM Interface with cyclone iii FPGA.In that i have used first 2 banks of fpga for ddr interface. I also make Vref pin as 1.25v. Totally i use ...
15 years agoI face this problem before. You have to do some setting because there is too much bidir pins for 1 Vref.:)
1st : Assigment-Device-Device and Pins option-Dual purpose pins(set all value to: use as regular I/O accept for DClock&nCEO. 2nd : Assigment-Assigment Editor- Change all DQ,DQS and DM pins to (Output Enable Group). For the Value column, set any number same for those pins. eg: DQ[0]->Output Enable Group->123456(Value) 3rd : Assigment-Pins(Change IO standard for all DDR related pins to SSTL-2 Class I.) You now are able to compile without any fail hopefully. I face this before and want to help you.:o Thank you: Shahril
