12 years agodemodulator with altera megafunction
hi, i've to realize a i-q demodulator for low frequencies signals with the classical scheme https://www.alteraforum.com/forum/attachment.php?attachmentid=9034 The input signal is a 1,3H...
12 years agodspbuilder should have separate entries for system clock and sampling rate. Your clock frequency I assume will be higher than sampling rate in which case you let the filter see the correct rate through sink valid which should be at your input rate.
