12 years agodemodulator with altera megafunction
hi, i've to realize a i-q demodulator for low frequencies signals with the classical scheme https://www.alteraforum.com/forum/attachment.php?attachmentid=9034 The input signal is a 1,3H...
12 years ago --- Quote Start --- how did you find n and Wn of FIR1 matlab function? Thanks --- Quote End --- cut off = 10Hz on a sampling frequency of 1KHz i.e. cutoff is 10/1000 relative to Fs of 1(1 cycle or 2pi) hence 10/1000 *2(pi) = 20/1000 pi = .02 pi n is experimental to get -60dB, you can use other options... apply freqz to see: freqz(h,1,0:.01:500,1000);
