10 years agoDelaying output of a module to close timing
I've created a module where two numbers are multiplied and the output is provided in a number of clock cycles. However, the output of the module (pdt1_out) is failing timing in that the setup slack ...
10 years ago --- Quote Start --- Thanks for your response, kaz; this is much appreciated. I will try using the same clock for the unsigned_mult64 module. I had switched to a slower clock in an attempt to close timing. I am actually trying to emulate multiplication using 64-bit integers (as on a desktop computer), so I would like the output to also be 64 bit. Here is the code that I am using for the pipelined multiplier. How would I add more pipeline stages inside the multiplier? What I am trying to do here is to infer a megafunction with a pipelined multiplication. Is this the right way to do so or does the output have to be 128 bits? Here is the code with timing issues:
module unsigned_mult64 ( a, b, clk, out);
// pipelined multiplier (4 cycles)
output out;
input clk;
input signed a;
input signed b;
reg signed a_reg0;
reg signed a_reg1;
reg signed a_reg2;
reg signed b_reg0;
reg signed b_reg1;
reg signed b_reg2;
reg signed out;
wire signed mult_out;
assign mult_out = a_reg2 * b_reg2;
always @ (posedge clk)
begin
// levels + 1 = pipeline = 4
a_reg0 <= a;
a_reg1 <= a_reg0;
a_reg2 <= a_reg1;
b_reg0 <= b;
b_reg1 <= b_reg0;
b_reg2 <= b_reg1;
out <= mult_out;
end
endmodule --- Quote End --- you need to use megawizard to get a mult that can be internally pipelined. This is the main timing bottleneck. external registers are ok (one stage for inputs,one for outputs) but any back to back registers would not help timing. 64 x 64 bits mult requires 128 bits. If you want 64 bits only then select 64 LSBs but provided the MSBs do not carry any part of result. Alternatively use 64 MSBs but that means division by 2^64
