10 years agoDelaying output of a module to close timing
I've created a module where two numbers are multiplied and the output is provided in a number of clock cycles. However, the output of the module (pdt1_out) is failing timing in that the setup slack ...
10 years agoThanks for your response, kaz; this is much appreciated.
I will try using the same clock for the unsigned_mult64 module. I had switched to a slower clock in an attempt to close timing. I am actually trying to emulate multiplication using 64-bit integers (as on a desktop computer), so I would like the output to also be 64 bit. Here is the code that I am using for the pipelined multiplier. How would I add more pipeline stages inside the multiplier? What I am trying to do here is to infer a megafunction with a pipelined multiplication. Is this the right way to do so or does the output have to be 128 bits? Here is the code with timing issues:module unsigned_mult64 ( a, b, clk, out);
// pipelined multiplier (4 cycles)
output out;
input clk;
input signed a;
input signed b;
reg signed a_reg0;
reg signed a_reg1;
reg signed a_reg2;
reg signed b_reg0;
reg signed b_reg1;
reg signed b_reg2;
reg signed out;
wire signed mult_out;
assign mult_out = a_reg2 * b_reg2;
always @ (posedge clk)
begin
// levels + 1 = pipeline = 4
a_reg0 <= a;
a_reg1 <= a_reg0;
a_reg2 <= a_reg1;
b_reg0 <= b;
b_reg1 <= b_reg0;
b_reg2 <= b_reg1;
out <= mult_out;
end
endmodule
