14 years ago
DEII GPIO Bidirectional problem
Hi, I am doing a project involving use the nand-flash chip through the DEII GPIO port. the data port for nand flash will be used for both input and output.
This is what I did:
1. declare the port as inout
inout wire [7:0] nand_data_inout,
reg nand_out_enable;
2. use an enable signal to switch between input and output
assign nand_data_inout=nand_out_enable?nand_data_out:8'bZ;
3. usage
in the next state logic, if next cycle, i need the port to be output, i will do:
nand_out_enable=1;
if I need it to be the input, then i will do
nand_out_enable=0;
To read the data, i will do the following:
LEDG_ID=nand_data_inout;
Problem:
I have tested with LEDs, so the output signal is correct, however, the read input seems like doesnt work at all, all I read is 1. Did I do something wrong here?
    --- Quote Start ---
    Does changing 8'bZ to 8'bZZZZZZZZ help?
    --- Quote End ---
    Thanks for you reply, but seems like its not working...
