14 years agoDEII GPIO Bidirectional problem
Hi, I am doing a project involving use the nand-flash chip through the DEII GPIO port. the data port for nand flash will be used for both input and output. This is what I did: 1. declare the ...
14 years ago --- Quote Start --- Does changing 8'bZ to 8'bZZZZZZZZ help? --- Quote End --- Thanks for you reply, but seems like its not working...
