13 years agoDefault latched outputs values
Hi guys, I'm working on a multi deck elevator controller using niosII and i thought it's better to relief the processor from handling the displays (floors + car motors display : up,down,1,2...etc ...
13 years agoyour design is all combinatorial with some latches. Not a typical fpga design but fair enough as good as it works.
You can either clock all changes or a quicker way is to have internal reset as clocked register: signal reset_int : std_logic := '0'; process(clk) begin if rising_edge(clk) then reset_int <= '1'; end if; end process; then connect reset_int with reset_n. That way the latches will start as all ones. for example: if reset_int = '0' do this elsif reset_n = '0' do this...etc If the tool optimised away reset_int register then you need to tackle it.
