19 years agoDefault drive strengths for Stratix III and Cyclone III
Note that Stratix III and Cyclone III default drive strengths on most I/O standards are set to OCT Rs for better signal integrity. On previous families they were set to max drive strength for best pe...
19 years agoYeah, Hyperlynx sims are the best way to go if you can do them. I try to use them whenever possible because it gives you the most accurate results since it takes into account your actual board topology and loading, etc.
