11 years ago
dedicated input clock I/O pin as regular input in Cyclone IV
I would like to use GLK3 dedicated input clock as regular user input on Cyclone IV EP4CE6E22
It seems OK but the fitter (Quartus 13.1) return the following warning:
Warning (176228): Can't pack node xxxx and I/O node xxxx -- I/O node is a dedicated I/O pin
Can I ignore this message safely?
    The warning message concerns an IO input that is not used as a clock. When I have this message (regular input on GCLK pin) the fitter report indicates a fanout of 0.
    I have tried to remove the pin allocation and the message disappears. Moreover, in this case the fitter report indicates a fanout of 2...
    I don't use clock going into general purpose. All input clocks are located on GCLKx pins.
    Yes, you can use dedicated clock input pins for general purpose input (but not output) signals. Indeed you can also use general purpose I/O for clock inputs too but if you can avoid it I would.
    I don't think that warning is (necessarily) related to such an assignment. I've just tried this and don't see a similar warning.
    Do you have a clock going into a general purpose I/O pin? I think that is more likely to result in such a warning. Quartus may find it difficult to route a clock, coming in on an I/O pin, to a large number of registers.
    Cheers,
    Alex
