9 years agoDebugging the Hardware fault
I have Cyclone III fpga board with Ethernet interface and JTAG connector for Active Serial Programming through USB Blaster. If I plug in the Ethernet connector - the PC is not recognizing the ...
9 years agoThe board is not recognizing the ethernet port also when connected to a pc also. I am ruling out the possibility of USB BLASTER non functional
