9 years agoDebugging the Hardware fault
I have Cyclone III fpga board with Ethernet interface and JTAG connector for Active Serial Programming through USB Blaster. If I plug in the Ethernet connector - the PC is not recognizing the ...
9 years ago1) Can you program the FPGA directly via your JTAG connector? - P1.
2) Will the FPGA configure from your serial PROM? - U1. 3) The FPGA looks to be connected up correctly. Are your power rails good - at the right levels? Are they noisy? (Perhaps not given how you generate them). Cheers, Alex
