Thomas16
3 years agoDebugging testusb problems
Hi all, We are verifying the USB ports on a new design based on the Cyclone V SoC. The port seems to work functionally okay. However, we ran `testusb` (as included in tools/usb) which produced some ...
aikeu
3 years agoHi Thomas16,
I think there is the limitation for soc board to perform all the available test under USBtest due to some configuration settings which relates to the USB operation.
I think will need to know which type of test which you required to run. Some of the common test which mentioned under the readme should be passing but eventually not all the test will be expected to pass.
http://www.linux-usb.org/usbtest/
Aik Eu
