12 years agoDebugging TDO on Cyclone V
Hello, I am making my first attempt at a custom Cyclone V 5CEBA4U15 board after using a rival FPGA vendor for several years, so I have probably made some rookie mistakes. The JTAG chain is bro...
12 years agoHi Dave,
Thank you very much for your suggestions; they pointed me in the right direction and quickly led to the problem. I had failed to understand the requirements of VCCPD on each bank. I mistakenly thought they only applied to bank 3 (which has the external JTAG signals), so I was trying to run bank 5 with VCCPD = VCCIO = 1.8v, which led to the behavior described above. The VCCPD pads are tied to VCCIO on an inaccessible layer on that bank, but I switched the entire VCCIO=VCCPD net up to 3.3v and now the JTAG chain initializes successfully. This requirement is listed on pages 5-8 and 7-5 of the manual, but I failed to grasp the concept of an i/o pre-driver supply. Thanks again for your help. Regards, Morgan
