19 years agoDebugging an FPGA over ethernet
ALTERA's quartus-III can be used to debug a VHDL code running on STRATIX-III using JTAG.
I'm looking for a debugger that will debug the FPGA over ethernet. The PC running the debugger will be connected to the FPGA using an IP to JTAG converter. Is it possible ? Thanks.6 Replies
That is what I mean.
I do not think that the currect release is certified on Microsoft Windows Vista at this time. I might be wrong. I was sort of joking with you on the topic. You are absolutely right about the price delta. - Altera_Forum
I do not think that the currect release is certified on Vista at this time. I might be wrong. I was sort of joking with you on the topic. You are absolutely right about the price delta. - Altera_Forum
--- Quote Start --- An ethernet enabled programming cable sounded fab until I checked out the price: $575. What a !@#$ rip-off. You could buy a brand-new Wall-Mart PC, including a Vista license, to do that job for just $300. Tommy --- Quote End --- Thank you for your reply. What do you mean by vista ? Is it Microsft's windows vista ? Thanks. - Altera_Forum
Except that Quartus II is not certified for Vista yet. :cool:
Tommy - Altera_Forum
You could use EthernetBlaster Communication Cable (Download Cable) that is available from Altera for configuring and debugging Altera FPGA based systems.
