14 years agoDebug Help (System ID mismatch, System timestamp mismatch)
Hello everybody, This is my first post on this forum, so please bear with me... I am trying to debug, but I am receiving the following errors in the 'Target Connection' tab. System ID mism...
14 years agoafter you generate the SOPC system you need to go into Quartus, compile the project, and upload the new .sof file into the FPGA (be careful, if you don't have the licenses for all the IPs you are using, then the project is compiled into a *_time_limited.sof, so be sure you are using the right one). Then it should pass the system ID/timestamp test.
