9 years agoDE4 pin assignmnet .csv file
Hello Folks, Where can I find (or generate) pin assignment file for DE4 board? Tried Pin Planner to generate the .csv file but that only generated the pins I used in my design. I want the whol...
9 years agoUnzip the example design, synthesize it, and then read the scripts to see how things work. You'll see that there is a constraints file implemented in Tcl. Learn how to use Tcl and constraints applied like this.
The DE4 comes in a couple of varieties, eg., a 230k and 530k version. I forget which board I have ... most likely whatever the script defaults to :) Using Tcl scripts for managing constraints is quite universal - with very minor changes the constraints style works for Xilinx Vivado too. Cheers, Dave
