12 years agoDE2i-150 - HSMC THDB-ADA Daughter Card (Analog to Digital Converter)
Hello all, I have recently received the THDB-ADA Daughter Card and downloaded the provided software. The Demonstrations folder provided does not include a program for the DE2i-150, and while I...
12 years agoHi ,
In the ADA feature it specifies that the board has clock source of 100 Mhz . The pdf has been attached for reference! The feature set of the ADA is listed below: 1. Dual AD channels with 14-bit resolution and data rate up to 65 MSPS 2. Dual DA channels with 14-bit resolution and data rate up to 125 MSPS 3. Dual interfaces include HSMC and GPIO, which are fully compatible with Cyclone III Starter Kit and DE1/DE2/DE2_70/DE2_115/DE3/DE4, respectively 4. Clock sources include oscillator 100MHz, SMA for AD and DA each, and PLL from either HSMC or GPIO interface 5. AD converter analog input range 2V p-p range. 6. DA converter output voltage range 2V p-p range. 7. DA and AD converters do not support DC signaling So does it imply the board has its own clock? if so how do we enable it? Thanks!
