17 years agoDE2_TV searching XY coordinates of pixels
Hi @all,
I am currently working with the DE2 Dev.&Edu. Board with Cyclone II. In my project I am supposed to do a simple blob detection. The blobs are represented by white dots on black background. Since I am new I decided to start with the DE2_TV example to become familiar with the dataflow. If I did understand it correct the program does the manipulation of the data pixel-wise, which means that the information which pixel it is actually manipulating should be available. But I am a little bit confused which register does hold the information. I thought it should be the ports oCurrent_X and oCurrent_Y from the VGA_Ctrl module, but if thats the case why is the register 11 bit. This would allow a resolution of 2048x2048 (I know this is not the correct relation, it's just a example). But the output of the VGA has only a resolution of 640 x 480, so the coordinates of X and Y should be lay inbetween. Can someone help me here? Where can I get the X and Y coordinates for the pixels? regards, Alex12 Replies
Do the coordinates change on every clock tick?
How can I make sure that I don't proceed a pixel twice or miss a pixel?
I have tested this code now with an wave input file. But every time when the procedure detects a pixel as above the threshold, the control variable proceedinga_run becomes undefined or represents 0 and 1 at the same time. Isn't possible to use register values in following iterations? Do they get lost? If I check for the previous position previousposx it works very well. Should I start from scratch or even change to SystemC ? I've invested now more than 2 months of work and don't make real efforts. Maybe doing it in Verilog was a bad decision?! thanks for your supportmodule run_line_detection(CLK_27, CLK_50, iReset, iVGA_R, iVGA_B, iVGA_G, iPosX, iPosY, iThresh, iVGA_BLANK, iDIG, oVGA_R, oVGA_B, oVGA_G, oTXD_DATA, oTXD_Start, ProceedingA_Run, previousPosX); // INPUT input iThresh; input iVGA_R; input iVGA_B; input iVGA_G; input iPosX; input iPosY; input CLK_27, iReset, CLK_50; input iDIG; input iVGA_BLANK; // OUTPUT output reg oVGA_R; output reg oVGA_B; output reg oVGA_G; output reg oTXD_DATA; output reg oTXD_Start; // INTERNAL parameter TRUE = 1'b1; parameter FALSE = 1'b0; output reg ProceedingA_Run; //flag to determine if pixel belongs to a run output reg previousPosX; reg previousPosY; reg pixelPosX; //store start position of run on X-Axis reg pixelPosY; //store start position of run on Y-Axis reg pixelRunLength; //count number of pixels belonging to run reg runRegister;//storage for detected runs reg foundRun; //global counter for detected runs reg writeBank; //flag to switch between write commands reg frameCounter; //counter for frames 1-3 to change pointer on run-register in SRAM reg counter; always@(posedge CLK_27) begin if(!iReset) begin previousPosX = -1'd1; previousPosY = -1'd1; ProceedingA_Run = FALSE; counter = 0; end if ( (iPosX <= 640) && (iPosY <= 480) ) begin //value > Threshold => pixel belongs to blob if((iVGA_R > iThresh) && (iVGA_G > iThresh) && (iVGA_B > iThresh) ) begin oVGA_R = iVGA_R; oVGA_G = iVGA_G; oVGA_B = iVGA_B; if(iVGA_BLANK) begin if(iPosX == (previousPosX +1)) begin //Pixel is start point of a new run if( ProceedingA_Run == FALSE ) begin ProceedingA_Run = TRUE; pixelPosX = iPosX; pixelPosY = iPosY; pixelRunLength = 0; end //increase number of counted pixels for current run pixelRunLength = pixelRunLength + 1; end else begin //Actually proceeding a run, but current pixel does not belong to it the end of the run is reached if( ProceedingA_Run == TRUE ) begin ProceedingA_Run = FALSE; //store run only if longer than 1 pixel if( pixelRunLength > 1 ) begin runRegister <= {pixelPosX, pixelPosY, pixelRunLength}; foundRun = TRUE; end else begin foundRun = FALSE; end end end end //end VGA_BLANK end else begin if(iVGA_BLANK) begin //Actually proceeding a run, but current pixel does not belong to it the end of the run is reached if( ProceedingA_Run == TRUE ) begin ProceedingA_Run = FALSE; //store run only if longer than 1 pixel if( pixelRunLength > 1 ) begin runRegister <= {pixelPosX, pixelPosY, pixelRunLength}; foundRun = TRUE; end else begin foundRun = FALSE; end end end //end VGA_BLANK oVGA_R = 10'b0000000000;oVGA_G = 10'b0000000000;oVGA_B = 10'b0000000000; end // threshold end //if ( iPosX <= 640 && iPosY <= 480 ) else begin foundRun = FALSE; end if(foundRun == TRUE) begin foundRun = FALSE; runRegister <= {8'd200, 8'd170, 8'd15}; end previousPosX = iPosX; previousPosY = iPosY; //change register for runs if end of frame reached if( (iPosX == 640) && (iPosY == 480 )) begin previousPosX = -1; previousPosY = -1; ProceedingA_Run = FALSE; end if(foundRun) begin tmpRun = runRegister; TXD_Buffer = {TXD_Buffer, tmpRun, 2'h0A}; TXD_Buffer_Flag = {TXD_Buffer_Flag, 5'b11111}; end if(TXD_Buffer_Flag) begin oTXD_Start = 1'b1; oTXD_DATA = TXD_Buffer; end else begin oTXD_Start = 1'b0; end TXD_Buffer_Flag = {TXD_Buffer_Flag, 1'b0}; TXD_Buffer = {TXD_Buffer,8'b00000000}; end endmodule - Altera_Forum
Yes, you are right. (oCurrent_X, oCurrent_Y) means coordinates for the pixels while (oVGA_BLANK==1). Never mind bit length.
