14 years agoDE2 codec help
module i2c (
CLOCK, I2C_SCLK,//I2C CLOCK I2C_SDAT,//I2C DATA I2C_DATA,//DATA:[SLAVE_ADDR,SUB_ADDR,DATA] GO, //GO transfor END, //END transfor W_R, //W_R ACK, //ACK RESET, //TEST SD_COUNTER, SDO ); input CLOCK; input [23:0]I2C_DATA; input GO; input RESET; input W_R; inout I2C_SDAT; output I2C_SCLK; output END; output ACK; //TEST output [5:0] SD_COUNTER; output SDO; reg SDO; reg SCLK; reg END; reg [23:0]SD; reg [5:0]SD_COUNTER; wire I2C_SCLK=SCLK | ( ((SD_COUNTER >= 4) & (SD_COUNTER <=30))? ~CLOCK :0 ); wire i2c_sdat=sdo?1'bz:0 ;reg ACK1,ACK2,ACK3; wire ACK=ACK1 | ACK2 |ACK3; //--I2C COUNTER always @(negedge RESET or posedge CLOCK ) begin if (!RESET) SD_COUNTER=6'b111111; else begin if (GO==0) SD_COUNTER=0; else if (SD_COUNTER < 6'b111111) SD_COUNTER=SD_COUNTER+1; end end //---- always @(negedge RESET or posedge CLOCK ) begin if (!RESET) begin SCLK=1;SDO=1; ACK1=0;ACK2=0;ACK3=0; END=1; end else case (SD_COUNTER) 6'd0 : begin ACK1=0 ;ACK2=0 ;ACK3=0 ; END=0; SDO=1; SCLK=1;end //start 6'd1 : begin SD=I2C_DATA;SDO=0;end 6'd2 : SCLK=0; //SLAVE ADDR 6'd3 : SDO=SD[23]; 6'd4 : SDO=SD[22]; 6'd5 : SDO=SD[21]; 6'd6 : SDO=SD[20]; 6'd7 : SDO=SD[19]; 6'd8 : SDO=SD[18]; 6'd9 : SDO=SD[17]; 6'd10 : SDO=SD[16]; 6'd11 : SDO=1'b1;//ACK //SUB ADDR 6'd12 : begin SDO=SD[15]; ACK1=I2C_SDAT; end 6'd13 : SDO=SD[14]; 6'd14 : SDO=SD[13]; 6'd15 : SDO=SD[12]; 6'd16 : SDO=SD[11]; 6'd17 : SDO=SD[10]; 6'd18 : SDO=SD[9]; 6'd19 : SDO=SD[8]; 6'd20 : SDO=1'b1;//ACK //DATA 6'd21 : begin SDO=SD[7]; ACK2=I2C_SDAT; end 6'd22 : SDO=SD[6]; 6'd23 : SDO=SD[5]; 6'd24 : SDO=SD[4]; 6'd25 : SDO=SD[3]; 6'd26 : SDO=SD[2]; 6'd27 : SDO=SD[1]; 6'd28 : SDO=SD[0]; 6'd29 : SDO=1'b1;//ACK //stop 6'd30 : begin SDO=1'b0; SCLK=1'b0; ACK3=I2C_SDAT; end 6'd31 : SCLK=1'b1; 6'd32 : begin SDO=1'b1; END=1; end endcase end endmodule i'm new to verilog. can anyone explain me the code please? :confused:
1 Reply
Try this book: verilog hdl (http://books.google.com/books?id=fcsipgsqkhkc&printsec=frontcover&dq=verilog+by+samir+palnitkar&hl=en&src=bmrr#v=onepage&q=verilog%20by%20samir%20palnitkar&f=false) by Palnitkar
