15 years agode2 board minimum voltage
hi
could I operate the de2 board with less then 9 volt ?13 Replies
yes and it works
I also check the verify checkbox and everything was ok but the board still remained in the previous state ( turn on on weak light) - Altera_Forum
The programmer screenshot looks like AS programming has been succesful. In case of doubt, you are also able to verify the EPCS data. Sucessful programming doesn't imply, that the code is valid for the respective FPGA, however. But that's nothing we can help with. Did you try to run the same code through (volatile) JTAG programming?
today I tried to burn again with two other cards
one de2-70 and another de2-35 I failed in both attempts ... is it even possible to burn with the as-programming mode? - Altera_Forum
maybe I need to use the altserial_flash_loader component?
The burning process still doesn't work I did everything that was said in the manual but nothing
In quartus there is no warning and as far as he consider everything is ok But I didn't get the code to burn on the card instead all of the lights or turned on in a weak light I added a screen shot of the programming window Hope someone could help - Altera_Forum
Hi
I was successfully burn something nut it's not my code... the altera de2 board have a blue power led on and every of the other green and red and lcd screen is turn on weak I tried to erase and burn again but I got the same result - Altera_Forum
hi
I followed the manual but when I press start I got this massage "Cannot start device configuration because no programming options have been selected for device chain" what can I do? - Altera_Forum
thanks a lot (:
Refer to the user manual chapter "Configuring the EPCS16 in AS Mode"
thanks ,
I did examine the schematic (wasn't easy to find) but I didn't thought about the minimum voltage needed to activate the regulator. so I guss that's way all of my gpio connections didn't work. do you know what do I need to do in order to burn my code into the DE2 memory execpt from switching the switch to prog state ?
