15 years agode2 board minimum voltage
hi could I operate the de2 board with less then 9 volt ?
15 years agothanks ,
I did examine the schematic (wasn't easy to find) but I didn't thought about the minimum voltage needed to activate the regulator. so I guss that's way all of my gpio connections didn't work. do you know what do I need to do in order to burn my code into the DE2 memory execpt from switching the switch to prog state ?
