18 years agoDE2-70 problem
Hi, I have DE2-70 with quartus/Nios 7.2, when I try to use a control panel the error "Fail to connect FPGA Board" appears. How to fix it?, please :)
17 years agomy DE2 Board doesn't see programming cable (USB Blaster). USB Blaster is embedded in DE2 Board. my other Altera board works fine. Quartus recognize the USB Blaster as soon as I connect to the board. Same cable is connected to DE2. But it doesn't show anything. It used to work. Is there anything to do with swithches. SW19 I set it to both RUN and PROG. But in either case, it fails to recognize USB BLASTER.
