11 years agoDE2-115 using GPIOs
I am trying to build a simple example which uses a statemachine to change a bit and then send that bit as an output to the GPIO. I am using a DE@-115 board with Quartus IIversion 13. I am using a Saleae logicdevice to monitor the GPIO outputs. Attachedis my code.
Things that work: Switches control LEDR. KEY controls LEDG. Assigning a SW(2) to the GPIOoutput myBit2 works. I can see theoutput change when I flip the switch during capture. Assigning a KEY to myBit works. What doesn’t work: Assigning clk to myBit Assigning data to myBit2 fromthe state machine Task: To control a GPIO output logiclevel with software.LIBRARY ieee;
USE ieee.std_logic_1164.all;
entity part is
Port ( clk : in STD_LOGIC:='0';
SW : IN STD_LOGIC_VECTOR(17 DOWNTO 0);
LEDR : OUT STD_LOGIC_VECTOR(17 DOWNTO 0):="000000000000000000"; -- red LEDs
LEDG : OUT STD_LOGIC_VECTOR(8 DOWNTO 0):="000000000"; -- green LEDs
KEY : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
myBit, myBit1, myBit2, myBit3 : out STD_logic); --GPIO 0, 1, 2, 3
end part;
architecture Behavioral of part is
signal clk1 : STD_LOGIC:='0';
signal clkout:std_logic:='0';
--clk <= clk;
type state is(state1,state2,state3,state4,state5,state6,state7,state8,state9,state10);
signal current_state,next_state:state;
signal data:std_logic:='1';
begin
Clock : process(clk1, clkout)
begin
if clk1 <= 'U' then clk1 <= '0' after 2 us;
else clk1 <= not clk1 after 2 us;
end if;
if clkout <= 'U' then clkout <= '0' after 2 us;
else clkout <= not clkout after 2 us;
end if;
end process;
process(clkout)
begin
current_state<=next_state;
end process;
process(current_state,next_state)
begin
case current_state is
when state1=>
data <='0';
next_state<=state2;
when state2=>
data <='1';
next_state<=state3;
when state3=>
data <='1';
next_state<=state4;
when state4=>
data <='1';
next_state<=state5;
when state5=>
data <='1';
next_state<=state6;
when state6=>
data <='1';
next_state<=state7;
when state7=>
data <='0';
next_state<=state8;
when state8=>
data <='0';
next_state<=state9;
when state9=>
data <='1';
next_state<=state10;
when state10=>
data <='1';
next_state<=state1;
end case;
myBit3 <= data;
end process;
LEDG(7) <= KEY(3);
LEDG(5) <= KEY(2);
LEDG(3) <= KEY(1);
LEDG(1) <= KEY(0);
LEDR(0) <= SW(0);
LEDR(1) <= SW(1);
LEDR(2) <= SW(2);
LEDR(3) <= SW(3);
myBit <= SW(0);
myBit2 <= SW(2);
end Behavioral;
1 Reply
Where is your output assignment to the GPIO?
