11 years agoDE2-115 USB example problems
I'm trying to run the DE2_115_NIOS_HOST_MOUSE_VGA example but in the c code from the nios II there is an error, in the line IOWR(CY7C67200_BASE,HPI_MAILBOX,0xCE01); Symbol 'CY7C67200_...
11 years agothe problem was that i'm using 14.0 Quartus version and example are in 11.1 and the links for the Include files in the Nios project are in "C:/altera/11.1/quartus...", so adding new Include files from "C:/altera/14.0/quartus...". solve the problem
But now when i try to run the project, shows new errors make: *** [../DE2_115_NIOS_HOST_MOUSE_VGA_bsp/-recurs-make-lib] Error 2 DE2_115_NIOS_HOST_MOUSE_VGA C/C++ Problem make: *** [obj/HAL/src/alt_alarm_start.o] Error 1 DE2_115_NIOS_HOST_MOUSE_VGA_bsp C/C++ Problem make[1]: *** [obj/HAL/src/alt_alarm_start.o] Error 1 DE2_115_NIOS_HOST_MOUSE_VGA C/C++ Problem and from the console Compiling alt_alarm_start.c... nios2-elf-gcc -xc -MP -MMD -c -I./HAL/inc -I. -I./drivers/inc -DSYSTEM_BUS_WIDTH=32 -pipe -D__hal__ -DALT_NO_INSTRUCTION_EMULATION -DALT_SINGLE_THREADED -O0 -g -Wall -EL -mno-hw-div -mhw-mul -mno-hw-mulx -o obj/HAL/src/alt_alarm_start.o HAL/src/alt_alarm_start.c nios2-elf-gcc: error: unrecognized command line option '-EL' make: *** [obj/HAL/src/alt_alarm_start.o] Error 1
