14 years agoDE2-115 ethernet-to-PC
Hi , Is there a example for DE2-115 board to have 2-way communication via ethernet with a PC . Or if someone can suggest any tutorial to build such a SOC design on this board . An example that...
14 years agoAssign a static address to the application and recompile the example project. Since the example is called "Simple Socket SERVER", so You need a client on PC. You may also run a sniffer to check packets.
