13 years agode2 115 board audio codec i2c address
hello everyone,
im trying to access audio codec and i faced a problem. what is the slave address of this audio codec? i looked into the demostration files for getting an idea about i2c bus. i saw these lines: //=========start=========== 6'd1 : begin SD = I2C_DATA; SDO = 0; end 6'd2 : SCLK = 0; //======SLAVE ADDR========= 6'd3 : SDO = SD[23]; 6'd4 : SDO = SD[22]; 6'd5 : SDO = SD[21]; 6'd6 : SDO = SD[20]; 6'd7 : SDO = SD[19]; 6'd8 : SDO = SD[18]; 6'd9 : SDO = SD[17]; 6'd10 : SDO = SD[16]; 6'd11 : SDO = 1'b1;//ACK //========SUB ADDR========== 6'd12 : begin SDO = SD[15]; ACK1 = I2C_SDAT; 6'd13 : SDO = SD[14]; 6'd14 : SDO = SD[13]; 6'd15 : SDO = SD[12]; 6'd16 : SDO = SD[11]; 6'd17 : SDO = SD[10]; 6'd18 : SDO = SD[9]; 6'd19 : SDO = SD[8]; going so far.. etc. but, i couldn't understand difference between sub addr and slave addr. the sub address may be register address. but, what should be slave address? i need your help thanks, can4 Replies
Hi can,
I need to implement ADC using Codec on DE2-115 board. Can you help me out with some example. thanks, vrv - Altera_Forum
can't you get the device address from the datasheet of the audio codec WM8731 ?
Hello canokcelik,
I'm studying the audio codec and if you take a look in another part of this code (clock_500.v block) you will observe that this address is fixed: wire [23:0]DATA={8'h34,DATA_A}; I dont know what 34h means, I just know that is the slave address. 35h means another address, but I forgot what it means... =/ Sub address is the address of the registers, as you said, for example: ROM[0] = 16'h0c00; //power down => (0000 110)(0 0000 0000) it means register 6 (R6), take a look in the datasheet. sub_addr binary settings ROM[1] = 16'h0ec2; //master => (0000 111)(0 1100 0010) it means register 7 (R7) I hope I have helped you and sorry for the bad english. - Altera_Forum
Hello everyone, sorry for delay.
i have solved the problem. The slave address is 0x34, as viniciuslagrota indicated in his reply. viniciuslagrota: h prefix in h34 means that following number's radix is hexadecimal. so it is converted to "00011010" in your example because of 8'h34(In here, 8 indicates that following number must has 8 bits). you can send me an email about what you are doing now. may be, i can help you about somethink.
