14 years ago
DE2-115 and SRAM using SOPC (Qsys)
Hello Everyone,
I need help pleeeeeeeeeeeeeese.
I am trying to initlize the SRAM on the DE2 board using a C program, and I thought I will do this using SOPC.
I've been told that the name of the SRAM interface on Qsys or SOPC is "Avalon-MM Tristate Bridge" but I have an error when I add it to my simple SOPC system; it says:
"Error: tri_state_bridge_0.tristate_master must be connected to An Avalon-MM Tri state slave"
The question is:
1) Where do I connect this "tri_state_bridge.tristate_master"? or
2) Does anyone know how to access the SRAM using SOPC or Qsys?
Please help
    You need both the component you mentioned: tristate bridge and tristate slave.
    Tristate Bridge slave port has to be connected to an Avalon bus master (usually this is the same which is connected to Nios data and/or instruction port). The other bridge port connects to the tristate slave device. In your case you should have a specific component for your sram. Browse the Qsys/sopc components for the one matching your sram.
    If you don't have it you can use the component wizard to design one. Actually, this is usually a simple *.tcl file defining your sram timing and pin connections.
