14 years agoDE2-115 and SRAM using SOPC (Qsys)
Hello Everyone, I need help pleeeeeeeeeeeeeese. I am trying to initlize the SRAM on the DE2 board using a C program, and I thought I will do this using SOPC. I've been told that t...
14 years agoYou need both the component you mentioned: tristate bridge and tristate slave.
Tristate Bridge slave port has to be connected to an Avalon bus master (usually this is the same which is connected to Nios data and/or instruction port). The other bridge port connects to the tristate slave device. In your case you should have a specific component for your sram. Browse the Qsys/sopc components for the one matching your sram. If you don't have it you can use the component wizard to design one. Actually, this is usually a simple *.tcl file defining your sram timing and pin connections.
