Kondepu
5 years agoDE10-Pro issue with opencl 20.3
Greetings all,
We are using Quartus Pro 20.3 and also Intel OpenCL SDK 20.3. We are facing the problem in compile even the vector_add example. The same is working fine with 19.1 version.
Internal Error: Sub-system: SIN, File: /quartus/tsm/sin/sin_
near_target_voltage.is_track_ half_vccio() || near_target_voltage.is_track_ half_signal_swing() || near_target_voltage.is_double( )
Processors in use: 16
Internal Error: Sub-system: SIN, File: /quartus/tsm/sin/sin_ simulation_interface.cpp, Line: 1768
Please find the attached log Quartus compilation log.
Could you please kindly let us what could be the problem!
Thanks a lot.
Thanks and Regards
Koteswararao Kondepu
1 Reply
- AnilErinch_A_Intel
Hi Team,
Please let us know whether the existing knowledge base article helps you in this issue.
Thanks and Regards
Anil
