DE10 lite How to simulate the design from within Quartus ?
- 1 year ago
Can I assume that you are using this link? https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=234&No=1021&PartNo=4
If yes, the user guide mention that you will need to used Quartus 16.0. If you want to use the latest version, you will need to do the migration and study the flow again to run the simulation.
If the above is link is not correct, kindly send us your link.
Yes, do let us the version of the Quartus that you were using. As different version of Quartus use different steps for simulation.
I am using version 23.1 build 991 11/28/2023 SC lite Edition.
What version should I change to? (as long as it supports the DE10 Lite)
- sstrell1 year ago
The version is fine but you have to install QuestaSim along with Quartus. Go to "Individual Files" here: https://www.intel.com/content/www/us/en/software-kit/825278/intel-quartus-prime-lite-edition-design-software-version-23-1-1-for-windows.html
- YigalB11 year ago
I have modelSim installed, according to the DE10-Lite user manual.
Simulation is running well on ModelSim stand alone, but so far I failed to run the verilog simulation or gate level simulation out of the Quartus tools menu.
ModelSIm version is 2016.10
