YigalB1
1 year agoDE10 lite How to simulate the design from within Quartus ?
I am newbie with the DE10 lite. So far I could create the RTL, pass the synthesis (still with some warnings to investigate). I could also simulate it with ModelSim that was installed according to ...
- 1 year ago
Can I assume that you are using this link? https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=234&No=1021&PartNo=4
If yes, the user guide mention that you will need to used Quartus 16.0. If you want to use the latest version, you will need to do the migration and study the flow again to run the simulation.
If the above is link is not correct, kindly send us your link.
sstrell
1 year agoWhat version of Quartus are you using? ModelSim (or in more recent versions QuestaSim) must be installed along with Quartus. If you didn't install the simulation tool and set the path to its executable in the settings, it won't work.
