hucklord
5 years agoDE1 SOC oscillator
I'm working with a high quality ADC that needs a low jitter, low noise clock source. My question is: what are the specs of the internal 50MHz oscillator of the DE1-SOC? I'm looking for crystal oscill...
EngWei_O_Intel
5 years agoHi there
There are some variations in the internal oscillator frequency because of the process, voltage, and temperature (PVT) conditions.
If you need a precise frequency for operation you must use an external reference such as a crystal oscillator based device or a known accurate frequency source.
Eng Wei
- hucklord5 years ago
Thanks for the reply. Isn't that the case for any oscillator? A datasheet would normally list the frequency variation, jitter, phase noise, etc., where can I find the datasheet for the oscillator inside the DE1-SOC?
- EngWei_O_Intel5 years ago
Hi there
The drift is per device basis. There is no specification published on how much it will drift across PVT (process, voltage, temperature). But it would not fit for accuracy requirement.
Eng Wei
