11 years agoDE1-SoC nios and sdram
so i've made a 16mb sdram controller to use as memory for the niosii i made in qsys, qsys is supposed to fix the clock difference itself implicit, so i just connect everything, and then connect the p...
11 years agoalso another thing to clear it up, that i missunderstood at first, the pll isn't supposed to be in the same component as the nios cpu... its supposed to be an external component.. then it works..
