9 years agoDE1-SOC 5CSEMA5F31C6 can't be detected
Hi All, I am using DE1-SOC 5CSEMA5F31C6. I can't detect my device. THE DE1-SOC is powered on correctly. I can see that USB Blaster II is installed correctly. Once I press Auto Detect button I ...
9 years agoI am using Quartus lite 16.0 (or known as web edition, on previous versions) - and this version is free. I can generate the sof file without any issue. After I installed the University Program packages, it provided me with the IPs required for the DE1-SoC board, which again compiles just fine.
If you still encounter the same failure even in the latest version of Quartus, I suggest that you contact Terasic support for help. Perhaps they've seen cases such as this before, and is able to advise accordingly.
