16 years ago
De1 Nios
hi,
i am using DE1 board, i created NIOS system i have some problem occur.
when i download system in nios ide "leaving target process paused" massage will appear, but i use DE1 NIOS example program answer will get. i am new user. any one help me to create NIOS system. i am using quartus 6.1.
    hi i have one more clarification, in the DE1 board example nios project they used 100 MHz clock, but in DE1 50 MHz clock(why - in DRAM they shift the phase of the clock also) and also in the reset, they used internal reset option with some time interval. (i saw in verilog code).
    Check that your clock and reset are properly connected to your SoPC system. Also check that you are meeting timing requirements.
    Jake
