DE1 Board broken??!
I added some extra hardware to the Terasic DE1 board by connecting it over the GPIO1 square header. When pressing the power button the board doesn't start up. When I remove my extra hardware it still powers up. However, I noticed that there are some pins not working anymore after trying my extra stuff :( I just drove all pins of GPIO1 high and measured that some pins aren't 3.3V! What's propably wrong with it and what can I do? PLEASE HELP:cry:15 Replies
I had not noticed.. yes there are many shorts!
Stripboard isn't really suitable for wiring stuff to the GPIO headers on a DE1, because the header pins are only one row of holes apart, so it's tricky to break the tracks between opposite pins on the header.
If you *didn't* break the tracks between them I'm not surprised the board got fried! If you look at the DE1's schematic, you'll see that pin 11 on the GPIO headers carries +5v, but the pin opposite, pin 12, is grounded. Likewise for pins 29 & 30, +3.3v and gnd respectively. With your board connected, +5v, gnd and +3.3v were all shorted together, which explains why it wouldn't start up, and why something got fried. - Altera_Forum
Maybe a large parasite capacitive load..
yeah, that's what I did. But it happened....
What about some fuses? - Altera_Forum
You have to carefully check your pcb before connecting it to FPGA, test it with a low-cost MCU before..
ok
Do you know how I can avoid shorts in the future? Maybe there's something I can solder on my experimental pcbs? - Altera_Forum
I don't have that FPGA unfortunately, only one DE0-Nano..
I don't know where I can find those test points, but there's a 3.3V test point on the pcb which is ok (3.308V).
When you use 7.5V DC adapter or USB cable voltage is regulted to VCCint of FPGA (ex. 1.2 Volt), check if voltage (VCCio and VCCint) on FPGA is ok
What's this onboard regulator you're talking about?
