DE0-Nano-SoC and VIP Frame Buffer II application
Hi Mats Bjorkvist,
Good Day.
Apologize for the delayed response.
>After I have initiated and started the Frame Buffer II with the Go-bit and D5M, CVI, FB II, CPR, CVO, and VGA
>interface monitors the Camera picture, a problem comes up. When Go-bit is set, then processor stops executing
>and going forward in the code. What could be the reason to the stuck/stop (I have opened the memory with
>mmap against memory area where the frame buffer intermediate buffers are allocated in RAM)?
I believe this could possibly due to the Go bit gets deasserted by default when enable run-time control.
You may refer to chapter 16.7. Frame Buffer Control Registers of the Video and Image Processing Suite User Guide that states " Setting this bit to 0 causes the IP core to stop the next time control information is read. When you enable run-time control, the Go bit gets deasserted by default. If you do not enable run-time control, the Go is asserted by default. "
Link:
Video and Image Processing Suite User Guide - 16.7. Frame Buffer Control Registers
Thank you for your patience.
ZulsyafiqH_Intel
