XNguy4
6 years agoDDR4 HILO in S10MX failed initialization
I am using the qts_hilo_ddr4_x72_1066MHz sample project to test the DDR4 HILO in the Stratix 10 MX development kit. I didn't change anything, except upgrading the project from Quartus 18.1 to Quartus...
XNguy4
6 years agoHi,
Lowering the frequency to 933 or 933.3333 caused error as shown below
I also made the test with
- Skip address/command leveling
- Skip address/command leveling & deskew
None of them works.
ybin
6 years agoAnother action:
If you have another board which works well. You can swap the DDR4 DIMM, to check the issue is related to board or DDR4 DIMM.
