8 years agoDDR3SDRAM IP-core, number of chip selects
hello everyone. I am trying to create DDR3-IP core. I want to connect two DDR3-SDRAM SODIMMs(64bits) in parallel. each SODIMM has two chip selects pins. so the case needs four chip sel...
8 years agoI'm pretty sure that if you use the hard IP (not the soft controller) in Cyclone V, you can use ping pong phy. Try adding the ip and check the parameter editor for the option.
