8 years agoDDR3SDRAM IP-core, number of chip selects
hello everyone. I am trying to create DDR3-IP core. I want to connect two DDR3-SDRAM SODIMMs(64bits) in parallel. each SODIMM has two chip selects pins. so the case needs four chip sel...
8 years agohello sstrell
thank you. I am using CycloneV (5CGXFC9...) if I need to create two separate instances, which means that data bus can not be shared right? I don't have enough pins for the second IP.
