14 years agoDDR2 Timing Problem in Nios System on Stratix III dev.board
Hey ... I am a student and relatively new to the FPGA topic. I have an Altera DSP development board wit a Stratix III FPGA. I'm trying since a while to create a Nios II System which uses the D...
14 years agoHmm.. Timing Analysis results are good but the DDR2 Memory is still not working in the NIOS 2 Eclipse environment.
At the moment I dont know what can be the reason. This morning I tried the same system with the discrete Memory chips on the board and it worked quiet fine. Do you can think of a possible reason?
